Help with jetting dispute.........?
Old May 2, 2001 | 12:18 PM
TurfBlaster's Avatar
Am I correct when I say the following: You have a stock Blaster-oil injection, 230 main, 32.5 pilot, needle 3rd. Ok, now you remove 20:1 oil-injection and switch to 32:1 pre-mix. Is it right to say your machine will now run richer due to less oil and more gas?
My friend insists that we follow the jetting guides for a certain pipe and filter setup, but with his oil-injection removed, I think that we don't need to go as fat as the guide says because it's already getting a richer mix than it was before. Somebody please shed some light on this!!
Thanks!
Old May 2, 2001 | 04:25 PM
WyoRider's Avatar
You are correct. It will be richer with the 32:1 ratio now. But, as always when jetting no matter what the pipe manufacturer or whoever says to jet at you should still do a plug chop and check the jetting yourself.
Old May 2, 2001 | 04:43 PM
Thanks WyoRider. One other question, on doing a plug chop do you normally get results (coloring on the porcelain) on a new plug right a way or does it take a while to start seeing the coloration?
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
