2002 Yamaha big bear 400
Old Apr 7, 2024 | 12:24 PM
michaelperkins69's Avatar
Default 2002 Yamaha big bear 400
Hi, need help. I've just recently got a Yamaha big bear 400 with a no spark issue, I was told it ran great before it lost spark anyways it turned out to be the cdi box. I have spark now and I've replaced the ignition switch, coil,spark plug, and also bought a new oem carburetor for it,checked all the wiring did all the test on the stator,pick up coil,rectifier, everything I can think of but it runs bad. It will idle fine but when I go to rev it up cuts out and backfires. I've adjusted the air/fuel mixture screw all the way in and out with no change. I'm at a loss any help would be greatly appreciated. Thanks.
Old Apr 7, 2024 | 06:56 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Is CDI oem? check charging system? brake switch maybe sticking or not working the cdi think the brake is on an put it limp mode
Old Apr 7, 2024 | 09:34 PM
It is a oem cdi box, checked charging system, I unplugged the rectifier and still does the same thing. But I will check the brake switch I didn't think about that. Thanks for your help I'll update when I get a chance to check it.
Old Apr 9, 2024 | 07:10 AM
Update on the big bear I unplugged the brake switch and still runs bad.
Old Apr 9, 2024 | 06:34 PM
Loved
Community Favorite
I think it has to twist tie wire together I cant remember to make a loop is brake light on?Is CDI new or used?
Old Apr 10, 2024 | 05:25 AM
Oh okay I'll try that. The cdi box was used bought it off of ebay. Thanks.
Old Apr 10, 2024 | 10:45 AM
Loved
Community Favorite
Can you post a video of this atv running let us hear it?
Old Apr 10, 2024 | 10:49 AM
I'll do it when I get home from work today.
Old Apr 10, 2024 | 05:17 PM
It will not let me upload a video.
Old Jun 7, 2024 | 03:04 AM
MichaelThatcher's Avatar
Any update?
Spoiler
Edit: Thanks for the update.
