Steering play in BALLJOINTS?
Old Jun 26, 2001 | 10:33 PM
YellowRaptor's Avatar
I have tightened the end nut on my steering shaft, and i now believe that the play (small amount) is actually coming from the tie-rod ends!!! Yamaha should cover this under warrinty? NO? And, are the ends known to wear out and have play so quick? can i tighten em....note, it's not the nuts on the tie-rod ends i think it may be actually in the joints. Is this normal? thanks
Old Jun 27, 2001 | 01:15 AM
TitanRacing25's Avatar
Hey man it's a yamaha anything could be wrong with it try everything!
Old Jun 27, 2001 | 09:01 AM
RaptorMom's Avatar
This is a very normal problem. Lots of Raptor owners don't even know they have it. Checkout Moto-Man or similar, order 12 bronze a-arm bushings ($ 5.95 each)for the Warrior (the same as the Raptor) and install. This will fix your problem. If money is tight then just order 4 and install on the upper a-arm, this is where your problem really is. You might have to order new sleeves from Riva if your sleeves are worn. Check out the diagrams on Riva's site for more clarification. Re-post if you have any questions.
/NotuRaptor (on vacation and can only remember my wife's id of RaptorMom)
bmxatv10
Oct 14, 2022 06:23 PM
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
2many2ride
Sep 27, 2015 04:35 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
