BLASTER BRAKES MAKE A WEIRD NOISE !! CAN ANY 1 HELP?
Old Jul 30, 2001 | 05:40 PM
RACEandRIDE4ever's Avatar
I have a 99 blastr and my right front brake has been making a clunking noise when i use the brakes.
CAN ANY ONE HELP ME ????
Old Jul 30, 2001 | 06:01 PM
ridnwarrior's Avatar
Check the bolts that hold the caliper to the a-arm. One of them might be missing.
Old Aug 5, 2001 | 03:16 AM
Blaster96's Avatar
Take off the hub and spray both sides with brake cleaner. DO NOT USE WD-40!! Mine did that and that fixed them.
Old Aug 30, 2001 | 03:15 PM
timewass's Avatar
It is caused by excess brake dust in the drum. If they were wet then the pads wore faster when used and there is more dust in there. Spray the inside with brake cleaner and you'll be good. Or just ignore it and it will eventually go away.
Old Aug 30, 2001 | 05:03 PM
250rampage2's Avatar
Check where the cable meets the drum, you may have a broken part there.
Old Aug 30, 2001 | 05:13 PM
sAyIt_fmf's Avatar
check to make sure the spring clip is in place.
Frisky2050
Apr 9, 2020 11:19 AM
Sandman2.0
Jul 21, 2015 09:03 AM
chammerbeck
Jul 17, 2015 08:06 AM
cSchwartz
Jul 12, 2015 07:42 PM
D-Hagz
Jul 4, 2015 02:19 AM
