2002 Banshee chain roller noise?
Old Aug 20, 2001 | 11:55 PM
jeffnrivercity's Avatar
Just thought some of you guys would know whats up,anybody else had this problem.We have ajusted the chain and the rear sag and still sounds like its gonna fly off.We have about 8hrs on it,and it sounds like it's getting worse
Any info would be appreciated
Thanx
Greg
Friend of Jeffnrivercity
Old Aug 26, 2001 | 03:16 PM
Somebody must know something..................
Old Aug 27, 2001 | 02:42 PM
croomman's Avatar
I have a bran new 2000 with 4 hours on it. It also makes the chain roller noise, I ve checked the tention all seems ok.
Old Aug 27, 2001 | 02:56 PM
Raptoryfn660r's Avatar
RIP Dear Friend
You needed to adjust your chain at 8 hours. You must have really been riding that banshee really hard. The chain on my raptor is loud if that helps. I have 44.75 hrs on my Raptor and its still in the deflection range. Chet
sAyIt_fmf's Avatar
I would not trust the markers for chain adjustment. I would bet that the noise is coming from a slightly crooked rear end.
If everything is strait...make sure you do not have the chain too tight.
I just replaced my chain rollers...they are pretty quiet...A little noise. But not very much.
Old Aug 29, 2001 | 11:38 AM
Thanks for the info,we will mess with it more this weekend at Sand Mtn NV.
Jeff
Old Aug 29, 2001 | 12:45 PM
NotuRaptor's Avatar
This is a real common problem with the Yamaha factory chain rollers (the lower one). You can replace it with the larger one from Moose and the noise will go away. The problem is Yamaha uses ball bearings instead of needle bearings.
Also if you run a 12 tooth on the front, you can expect a lot more chain noise.
Old Aug 29, 2001 | 06:00 PM
sparky2001's Avatar
The truth is that the noise you are hearing is normal. BUT, you should really look at the chain adjustement. They tend to be really tight when they are out of the factory and that made it sound louder. Mine was so tight that I thoght that it was going to brake. If you can change it now for a better, lager and wider chain slider.
Good Luck
atvcollector
Sep 8, 2015 05:11 PM
chewy78
Sep 8, 2015 10:37 AM
bmark0610
Sep 7, 2015 09:42 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
byronman
Sep 6, 2015 06:34 PM
