raptor carb
Old Aug 22, 2001 | 12:53 PM
bansheeman351's Avatar
i just adjusted the carbs on my raptor. i adjusted the fuel mix screws. so setings were like at 2.5 turns out. but they wernt exactly the same. now i have them set at 3 turns out with the snorkle taken off and it mad a big diff in power. are these screw suposed to be the same. and it i wanted to would i be able to ture the screws to 3.5 turns out. or is there a limit on how many turns they are suposed to be turned out. thanks
Old Aug 22, 2001 | 01:05 PM
raptorridah's Avatar
ok ill try it
Old Aug 22, 2001 | 05:52 PM
trublue's Avatar
NO! is the answer(s) to your questions. This is a COMMON misunderstanding and i think that this is causing alot of dudes alot of grief. Here is the deal -- The Mikuni carbs are flowed INDIVIDUALLY and the optimun A/F screw setting is found and set. EACH CARB IS UNIQUE AND HAS ITS OWN OPTIMAL SETTING !!! is that clear? so just because left is 2.5 turns, that DOESN'T mean the right is also. Just cuz your buddy's left carb is 3 turns, yours could be 2 turns !!! OK, OK???? That is why Yamaha is VERY clear ( also in the service manual) that BEFORE you go adjusting the screw, you need to record the FACTORY setting for each carb. Once you know that, you can change to your hearts content, but always set it back to "stock". and each raptor's "stock" setting IS DIFFERENT. Weird, but true. Yamaha states that the stock setting is between 2-3 turns. That is true, generally. If yours is 3.5 turns, don't sweat it.
Also, i have seen posts saying that you turn IN the screw to RICHEN the mixture. WRONG! the a/f screw on the raptor is turned OUT (CCW) to richen it. Other carbs are different. Hope this clears things up.
BTW, my "stock" settings are:
LT - 2.25 turns from seated.
RT - 2.5 " "
How 'bout YOU!!!??? (no, plz. i could care less. it's a JOKE ! ) later.
Old Aug 22, 2001 | 06:20 PM
Raptoryfn660r's Avatar
RIP Dear Friend
Thanks Trublue. You made it clear. I know my Raptor has 2 carbs and I can see them. I am keeping my Uni and my stock air filter clean and as well as mine runs I am not touching nothing. Thanks again, for the info on recording if you do decide to mess with carbs. Chet
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
