Sand Tire Direction
Old Oct 17, 1999 | 11:48 PM
dman007's Avatar
I just bought a pair of used Kenda Dune Runners. My question is, which tire goes on which side. The rib the runs down the middle of the tire is flat on one side and beveled on the other. Which way should the rib be, flat out, beveled out? Thank you in advance for your assistance.
Old Oct 19, 1999 | 10:09 AM
dman007's Avatar
Won't anyone out there help me?
Old Oct 19, 1999 | 01:26 PM
Bigdog's Avatar
Just use some common sense man. If you sat the tire in some water which way would you position the paddle to move the most water. If you can picture that then I think that it will start to come to you.
Old Oct 19, 1999 | 02:18 PM
dalegoldston's Avatar
assuming you are talking about the front tires, put the flat side in. It turns the sand away from you.
Old Oct 19, 1999 | 08:42 PM
dman007's Avatar
Thanks dalegoldston, I was thinking that was probably the right way using common sense but wasn't sure.
BigDog, my common sense plus the directional indicators on the tires made it clear as to how I should run the rear paddles. However, Kenda Dune Runners are FRONT tires and not so easily figured out using common sense.
89Lt250r
Sep 7, 2015 07:53 PM
Logan Collins
Sep 5, 2015 08:03 PM
lancemll88
Sep 5, 2015 03:16 AM
Jul 24, 2015 11:57 AM
