FLIP RAPTOR FRONT RIMS =WIDER STANCE
Old Sep 8, 2001 | 02:25 AM
VMAX12's Avatar
I seen a raptor with the front rims fliped so the offset is to the
outside. he had to drill a hole and move the valve to other side. it
looked good. its a cheap trick!!!!
01 BLU 660R
Old Sep 8, 2001 | 08:36 AM
chasman's Avatar
the only problem witht that is it increases the bump stear.
Old Sep 8, 2001 | 03:53 PM
RaPtOrRiDr01's Avatar
flipped my front wheels around but insteadof drilling another hole I used like 3 washers on each lug to be ble to clearthe valve stem. Works Great! Just make sure u use some loctite to be sre ur nuts dont fall off.
Old Sep 8, 2001 | 04:07 PM
Joey9's Avatar
Just wondering. What does the valve stem interfere with the backing plate or brake caliper or both? Just out of curiosity. Thanks.
Old Sep 10, 2001 | 11:58 AM
vraptor's Avatar
Rather than flip my rims (or use spacers) I have a set of douglas rims with a 1" offset which work really well. they sent me the 2" offset first and I sent them back, they left my brake calipers exposed. but the 1" offset are great. You can also flip your rims around,plug up the original valve stem and have a new one drilled into the other side.
Firefighter400
Oct 8, 2022 06:38 PM
coldnorthpol
Jul 14, 2015 11:22 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
