ANY TIPS ON DURA BLUE INSTALL?
Well i just ordered a dura blue axle has anyone installed one on a raptor yet i was wondering how much of a pain it was and how wide you went?
01 BLU 660R
GYT-R FRONT BUMPER
GYT-R SIDE FRAME COVERS
GYT-R HOUR/TACH- SHOCK COVERS
PRM ENGINE SKID PRM BAJA GRAB BAR
PRO DESIGN KN FILTER+ 150-155 MAINS 25 PILOTS
12 TOOTH
WILDSKINZ HEADLIGHT COVERS
UNI CRANK FILTER
DURA BLUE ELIMINATOR +4
01 BLU 660R
GYT-R FRONT BUMPER
12 TOOTH
UNI CRANK FILTER
I put the eliminator 2+2 (really +3 or +5) on a couple of weeks ago, the install was easy, the problem I had was no instructions came with it, I had to go online www.durablue.com to get intructions. the first line is note the order of all the parts before taking them off for prior to installation (oops). still all in all it took about an hour, the axle lock nut is improved over the ones they had 5 weeks ago, we installed an X-33 on a friend of mines which has the old locknut, it came loose the first ride out. I have about 6hours on mine and it is much improved, doesnt come loose at all
just installed my axle. it went good took about 40 min from start to finish. hopefully i will never have to change it again! i used lock-tite so it better not come lose!! i measured the outside tire dim and it now sits at 48 in. just bearly fits in my 97 f-150 flareside..
01 BLU 660R
01 BLU 660R
UPS dropped off my X-33 at work, I went home and installed it on my lunch break. About 1 hour. It was easy.
I think if you don't use a pipe wrench on the axle nuts, they will stay tight for you. I use some Jumbo open end adjustable (Crescent) wrenches. My axle nuts NEVER come loose on any of my ATV's.
Don't over tighten the first nut and deform parts in the housing, which may cause a nut loosening problem.
jrooker6
Apr 23, 2016 07:36 PM
