need help with my banshee!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 14, 2001 | 06:54 PM
lange's Avatar
when i started it up today it didnt run right exhaust was only comming out the right side i read something about this befor but i cant remeber what it was but i no it wasent good any help i can get would be great
Old Sep 14, 2001 | 08:12 PM
bansheeman69's Avatar
same thing happened to me it is the rings. if you ride it for a while you will wreck the engine so you probly are goona need new pistons or new rings you are suppost to change the rings after about 25 hours off riding or it will hurt the engine really badly. you have to probly change the piston rings and it will be as good as new. ok?
Old Sep 14, 2001 | 10:21 PM
btodd's Avatar
The problem could be as simple as a bad spark plug in the non-firing cylinder. Have you checked anything out yet?
Old Sep 14, 2001 | 10:33 PM
otterbob's Avatar
sounds like a fouled spark plug.
Old Sep 14, 2001 | 10:59 PM
lonestarbanshee's Avatar
Fouled Plug... If you have taken your carburetor off, it can also be the air equalizer tube. Put a new set of NGK's in it, if that doesn't fix it, let us know
Old Sep 14, 2001 | 11:07 PM
i think that it was what i said bad rings. it wouldnt start if it had 1 bad spark plug, i think because 1 of mine was bad and it didnt start.
Old Sep 15, 2001 | 11:23 AM
lange's Avatar
i will try new plugs today hopefuly it will work any other sugestions
Old Sep 15, 2001 | 12:31 PM
LT80killer's Avatar
It will start/run on only 1 good plug bansheeguy69..
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
