BANSHEE PROBLEMS PLEASE HELP
Old Sep 25, 2001 | 09:34 PM
MadHandle8169's Avatar
I have a 1989 banshee and the left side of the bike is running good. It has good compression, is firing well, and the left silencers air that is coming out is warm like it is suppposed to. But my right side isnt. It has good compression but its not firing well i checked te spark plugs and the reeds. When the reeds were opened there wasnt a gasket on it could this be the problem. The right silencer is also shooting out cool air and im not sure but i dont think its supposed to be like that. If anyone can make any suggestions I would be very aprreciative.
Old Sep 25, 2001 | 10:40 PM
lonestarbanshee's Avatar
Have you recently taken your carb(s) off? If not, mine does it when I have the gas turned off, or its low on gas, or the plug's fouled.
I suggest an NGK BR8ES and mix your oil 32:1, and check everything. If you have taken your carbs off, tell me.
Old Sep 26, 2001 | 08:55 PM
No I havent taken the carbs off but i think I figured out when I was taking out the reeds and the retard who had the quad before put the left piston in backwards!!!!!!
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
