Razr's or ITP Shredder's?
I have been looking for a new set of tires for my Banshee and a little undecided. I was wanting some input from other riders to help me decide. I am torn between the Razrs and the ITP Shredders. Would someone steer me in the right direction. To help out, my quad is slightly modified and I mainly ride trails.
Brian
Brian
Both are excellent tires. The only problem is you will wear them bald very quickly. Both of these tires have a very soft compound. This gives you great traction, but at the expense of tire life. Both tires will perform almost identicly. If I had to pick between the 2 I would take the razrs. They have alittle harder compound so they will last you alittle longer.
Jayson Blough '99 Banshee, '97 Warrior, '96 Blaster Yes I like Yamaha
[This message has been edited by jblough (edited 12-07-1999).]
Razrs and GBC(not ITP) Shredders anrn't exactly the same. THe Razrs and Shredders are made by the same main company. Both are soft compound tires but don't wear out fast though. The Razrs are more of a XC tire with spaced H pattern while the Shredders are more of a MX tire with a tight X patternt.
Evan Johnson 88 LT250R 99 400EX
