Airbox mods
Old Dec 7, 1999 | 01:09 PM
Mud_Runner's Avatar
I'm takin everyones advise on modifying my 98 wolverine's intake system. Can someone spell out to me exactly where to drill the lid without makin it to vulnerable to the mud bogs. Also if I go with a Pro-Flow system do I also need to replace the box to carb tube? If so what's the best way to seal it? What size main jet should I start with? Thanks for all the great advice, It's nice to get away from all those biased dealer opinions!!
Old Dec 7, 1999 | 05:55 PM
BIGBEAR4x4's Avatar
It would be stupid to drill some hole if your airbox if you go muddin or play in water a lot. I doubt there is a place where it would not be vulnerable. But maybe u could add another airbreather by boring out a 2 inch hole then stickin some pvc pipe in it and route it up around your handle bars.
Old Dec 7, 1999 | 09:27 PM
JohnR.'s Avatar
Don't drill it at all, if you know you are riding in dry conditions then take it off. If you think you may do some mud bogging then put it on. No matter where you drill it it will be vulnerable.
Old Dec 8, 1999 | 03:05 PM
Harold's Avatar
do a search under Harold to see how i modifed my air box.
Harold Wells Raleigh NC 98 Wolverine& 97 Timberwolf Blueribbon Coalition Member
Old Dec 8, 1999 | 04:10 PM
hot_shoe_cv's Avatar
Mud_Runner,
I run thePro design system on my Warrior & I am going to assume that yours is basically the same.
you don't need to replace the boot to the carb..you'll have to remove the air box & drill two holes in the end to mount the aluminum billet that holds the new filter. Full instructions come with the kit & it's quite simple to install. You do have to make sure the o-ring supplied fits correctly between the billet & the airbox, so that it is water tight. I run a Moto force vented lid from Jas. Lucky. The vents are elongated on the right side of the box so that a moderate amount of water will by- pass the filter, going to the bottom of the box. You can remove the drain plug in the box to let the water out. Unless you just sink the bike, it should work fine.
BTW, according to Jas Lucky, the Moto force lid allows 90% of the air flow that no lid passes, still giving water protection.
For the main jet, if this is the only mod you're doing, I'd run a 150 main. Your stock is a 145, but unless you are sure of the type you should pull it and check b4 buying a new one. Yamaha uses two different styles inter-changeably within the same model & year; a round head with a screwdriver slot & a smaller hex head type. They're about $3.
THE AZ HARD PACKER, calmiller@kachina.net
save the public land FOR you, not FROM you..join the Blue Ribbon Coalition online @ www.sharetrails.org
[This message has been edited by hot_shoe_cv (edited 12-08-1999).]
Old Dec 8, 1999 | 05:25 PM
BIGBEAR4x4's Avatar
Hot shoe if he is out riding all day the water will add up in the airbox. Wouldnt be fun to have to stop riding and drain your airbox every 20 minutes or so.
Old Dec 8, 1999 | 10:39 PM
Mud_Runner's Avatar
Great advice!! I feel much better educated. I think I'll add an additional breathing tube that I know I'll be able to seal and terminate up above. Thanks Again
Mud_Runner 98' Wolverine,Warn Winch, Aluminum Skid plate, A-arm guards.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
mbriggs
Sep 13, 2015 10:47 AM
1ArmBandit
Sep 8, 2015 08:59 PM
