Banshee Chain Adjuster Issue
Old Dec 19, 1999 | 12:12 PM
sndnyrface's Avatar
I have a '00 Banshee and love it. The only issue I am having is the chain adjuster slide bolt keeps loosening off resulting in my chain loosening up. It has happened twice now. I was wondering if anyone else is having this issue. I am considering loctite if it persists. I'd rather not have to deal with my chain coming off and the associated collateral dammage.
Skene '00 Banshee
Old Dec 19, 1999 | 01:13 PM
hot_shoe_cv's Avatar
sndnyrface,
I had this happen on my Warrior once also. I,ve never examined the actual adjustment setup on the Banshee, but on the Warrior there are two hub bolts that must be loosened prior to adjusting the chain & I evidently failed to tighten both bolts after adjusting the chain, causing the entire hub assembly to move forward in braking.If the Banshee has the same axle system, that could be your problem; if so you can e-mail me for the torque specs on the two bolts
THE AZ HARD PACKER, calmiller@kachina.net
save the public land FOR you, not FROM you..join the Blue Ribbon Coalition online @ www.sharetrails.org
Cole Hadden
Jun 15, 2025 09:05 AM
Unzzy66
Jul 11, 2015 10:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
MNatv89
Jul 7, 2015 11:36 AM
