raptor airfilter
Old Oct 12, 2001 | 11:24 AM
mster's Avatar
just picked up my new raptor and would like to change the air filter set up before anything else. what is the best set up?
does pro design have a raptor setup? i put one of those on my warrior and really like it.
what do i do for the carb boots ? whats the best fix?
thanks!
Old Oct 12, 2001 | 06:23 PM
otterbob's Avatar
yes i put a prodesign proflow on my raptor. i recommend it. you have to cut a few tabs out of the airbox and lid but nothing major.
Old Oct 12, 2001 | 11:12 PM
95Warrior's Avatar
I put a ProDesign/K&N/Outerwear on mine. Make sure you rejet, even with a stock pipe. I picked up the K&N Stage 2 kit for $70, I hear Rocky Mountain hasit for $50. The jet kit comes with new needles, main jets, diaphram springs, and excellent instructions how to put it all together. For the carb boots, check to make sure the clamps are tight and richen up the idle mixture and you'll be all set. Congradulations on the new ride.
Old Oct 12, 2001 | 11:24 PM
otterbob's Avatar
ive got the foam and i didnt need to rejet mine. i made no modifications to the airlid or box for flow. i did the mod for a piece of mind standpoint. i hear the foam filter is the better choice for dusty or sandy conditions. ive experienced no performance gain at all, even though i didnt expect too. if you went with the k&n you might, then you might need to rejet too.
Old Oct 13, 2001 | 12:57 AM
chasman's Avatar
I also have the pro design set and like it very much. As far as the carb fix problem... I used zip ties and haven't had them blow off yet.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
