What are some good performance parts for my blaster?
Since you already have a pipe and silencer, you should look into getting a reed spacer. Then you could get your motor ported.. or bored. Just about any graphics kit will make a quad look better... But they're pretty expensive.
Out of all these, I suggest the reed spacer. Boyesen makes a good one, and I have a Hy-Tech on my R.. It seems to be pretty good.
Get a vito's 240cc big bore kit. it comes with everything you need including the high compression piston, sleeve, rings, and gaskets. it is only $250.00 and the sleeve is already ported. it sounds like a really good deal and should give you plenty of power.
The RAD valve really works better on higher CC engines. For lower tech, compression, and cubic centimeter engines, reed spacers do better.
Yamahagye, the Vito kit is only $250??? I was thinking more. I would get that if I were you!
I'm sitting here looking at a dirtwheels ad from vito. it says "BIG BORE KIT includes super stock piston kit, topend gasket set, and performance ported sleeve. Labor not included. $249.95" The piston alone is supposed to give you 5HP midrange through topend. the 240 kit should give you around 9-10 more Hp, maybe even more, if i had to guess. the price is almost too good to be true.
I found a Boyesen Rad Valve dyno test. The results aren't very good according to this dyno. [img]i/expressions/face-icon-small-frown.gif[/img]
Check the follwing link for the test http://www.mobiledyno.com/sys-tmpl/s...&UID=10006
Don't waste your money on a rad valve. Just get a good set of reeds like boyesen or fmf and you will notice something differant. Also a reed spacer is cheap and adds quit a bit of low end torque. Hey you could always turn to alki and nitrous with a turbo?
