WR200
Old Dec 27, 1999 | 04:58 PM
Kiwi-Craig's Avatar
Guys
Yamaha has made many variations on the 200 engines; a lot of these have never been seen in the states because of your EPA type legislation. There is a DT200 water-cooled trail bike still in production I think outside the USA, These engines are all very similar as can be seen by the redundant water pump housing in the side case. this housing also actuates the powervalve used on these watercoole rockets. If you are serious I can look through my brothers microfiche sets (he's a Suzuki and Yamaha Franchise dealer) and come up with some comparisons. If you find a water-cooled WR or DT you might as well use the radiator etc of it as well as throwing the entire engine in, sell the old air cooled relic !!! for parts.
Engine kits, check out Trinity at http://www.trinityracing.com/
They are really onto it guys.
Kiwi-Craig
Crainic@ihug.co.nz
Old Dec 27, 1999 | 06:28 PM
EdSmith's Avatar
You serious? I'd really like it if you'd look through the fiches and tell up which motor is the same as the Blaster but water cooled. If I could be sure about which motor I'd need parts from I'd give it a try.
BTW, the DT200 is made in Australia, I belive.
Thanks a ton!
Smitty4
Jan 18, 2005 06:02 PM
99fasterblasters
Oct 16, 2000 05:12 PM
