1998 Banshee problem need help
Old Jan 2, 2000 | 05:02 PM
THEXOTIC1's Avatar
i have a 1998 banshee that was not started since july i ran the carbs dry before it sat it has toomys and the carb are jetted at 280. The bike will start but idel as soon as you give it gas it dies i pulled the carbs off and cleaned them put them back on and its still the same. My friend also has toomies on his banshee and has the carbs jetted at 300 what do u guys run as a main jet
Thankx in advance
Alex
Old Jan 2, 2000 | 05:22 PM
hot_shoe_cv's Avatar
THEXOTIC1,
Did you drain the tank? It sounds like you still have some varnish in the system some where. What about the jets? did you remove them & spray with carb cleaner, specifically the pilot jets which control the mixture from idle to 1/4 throttle? Use compressed air after a liberal dose of carb cleaner on the jets.
I doubt that the main jets are your problem as they affect the fuel mix at upper rpms (3/4 to full throttle. I would pull the slides while I was at it & spray them & the needles & needle jets (where the needles rests).
THE AZ HARD PACKER, calmiller@kachina.net
save the public land FOR you, not FROM you..join the Blue Ribbon Coalition online @ www.sharetrails.org
[This message has been edited by hot_shoe_cv (edited 01-02-2000).]
Old Jan 2, 2000 | 07:41 PM
THEXOTIC1's Avatar
Yes i did drain the tank and the carb bowls i also cleaned the main jet and the smaller jet the carbs were clean when i took them apart i put new plugs in and still the smae problem air filter is clean. When i remove the plug from the head alot of smoke comes out of the spark plug hole so i am thinking my reeds are stuck or opened a little. Cause the smoke is not escaping
Alex
Old Jan 2, 2000 | 08:52 PM
dominator's Avatar
Also think about temperature, and how it effects the jetting. It may be right for a 90 degree day, but what about 15 degree day. Where do you live?
Old Jan 6, 2000 | 10:42 AM
THEXOTIC1's Avatar
Hey guys I found the problem with the 98 banshee after completly cleaning the carbs and checking the reeds we disconected the TORS carb system and jumped the to wires on each side together. The thing runs great. What does this tors system do anyway . We removed this on an 87 with a carb cap kit
Alex
Did anyone else have this problem with the tors system . I also had this problem with a 91 blaster a few years back
Old Jan 6, 2000 | 11:13 AM
SandmanBlue's Avatar
The tors system acts as an ignition cut out for two different things. One is for the emergency brake (to keep the engine rpm limited so you don't ride off with the brake on or for safety reasons), the other is in case the throttle is stuck wide open (but I don't know how it knows you are not wanting it wide open). These things come directly from a local Yamaha dealer. If you disconnect the tors box, located on the frame rail above the left cylinder, it will effectively stop it from working. There is no need to jumper any wires after disconnecting the box. It has a single plug connector that can be left dangling.
If you are still having a hard starting problem, run a compression check. If you don't have a gauge, they are cheap (about $25) and can be bought at an auto parts store. Buy one that has a pressure relief valve. I'd recommend the gauge be part of any owners tool kit.
Cole Hadden
Jun 15, 2025 09:05 AM
honda71
Jul 12, 2015 05:56 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
honda71
Jul 8, 2015 02:13 AM
Jul 7, 2015 11:00 PM
