Reverse Override On Kodiak& Grizzly
Old Jan 21, 2000 | 12:27 PM
GrizKo's Avatar
Is their a way to override the reverse safety on Yamaha ATV'S I find it extremly annoying when your in mud and you are in reverse and just before you get out or get A momentum the stupid thing starts cutting out,the Kodiak is worse then the Grizzly.Both are 2000's any help would be appreciated.
Old Jan 21, 2000 | 07:43 PM
Jeepers's Avatar
what reverse overide?? I don't have any trouble busting rpm's in reverse with mine
Old Jan 21, 2000 | 10:53 PM
GrizKo's Avatar
You meen to tell me that your atv does not sputter&couph when you are in reverse and exceede a wheele spin,please tell me where you purchased your bike I want one! Polaris & Kawasaki have override buttons for their reverse,how come Yamaha does not do the same.
Old Jan 21, 2000 | 11:13 PM
SportKod's Avatar
My 2000 Kodiak seems to do fine in reverse. No coughing or sputtering.
Old Jan 21, 2000 | 11:21 PM
GrizKo's Avatar
Sportkod try it in some mud,overall I agree it works fine but in reverse in mud or snow it sucks!
Old Jan 22, 2000 | 12:10 AM
mpbspb's Avatar
You don,t even have to put it in mud or snow, just put it in reverse and give a lot of throttle. I've been on 3 diffirent kodiaks that have this problem. Surely someone can help!?
Old Jan 22, 2000 | 09:14 AM
etkimball's Avatar
Mine cuts out also, if you find out how to override the limiter switch let me know also. I would like to have full power when backing.
Old Jan 24, 2000 | 11:17 PM
y2kodiak's Avatar
Why I have not done this said alteration.
I would suspect the best way to find the
Reverse Rev-Limiter, would be to Trace the
Ignition Route and the reverse light Circuits
as it appears to be a Capacitive/Delay type
of limiter, which limits Ignition pulses
to a specified # over a given time frame,
which would explain the backfire when in
reverse.
Once the culprit is located, might be in CDI
box itself, use a coated wire or equal or
heaver gauge to Jump(bypass)the Circuit.
I am not sure if this is the right way(but it seems reasonable), and I can accept NO
responsablity for Personnal Injury, Damage
to Quad, Voiding of Warrenty or any other
Negitive Results Arising from my Suggestions.
Good Luck
Great ***?
(Fill in the Blank)
Y2K
Old Jan 28, 2000 | 12:28 AM
azrob's Avatar
On the Grizzly you can remove that cable which requires you to step on the brake peddle when you want to shift into reverse. It runs from the brake peddle to the front of the shifter box itself. Removing it won't cut off the rev limiter though.
Old Jan 28, 2000 | 05:35 AM
Jeepers's Avatar
I've been reading through the manual and find that there is a reverse switch and a speed sensor shown in the schematics. Whether these control a rpm limit I don't yet know. I will experiment awhile and let you know
