banshee compression- how much??
Old Nov 18, 2001 | 07:10 PM
mster's Avatar
what should the compression be on a stock 96" banshee be?
i was getting 80psi on both cyl but only after a series of kicks. is this the proper technique??
Old Nov 18, 2001 | 10:05 PM
454's Avatar
454
stock is 130psi and you need to rebuild when it gets to around 100 when you test it take both plugs out put the tester in one hole and hold the gas wide open and kick it till the gauge stops moving hope this helpes 454.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
