What do I need to know about when installing a Durablue axle on my Raptor??
Old Dec 3, 2001 | 02:00 AM
MEAN1's Avatar
I'm buying a Durablue axle and would like to know the steps to install it? Any tips or tricks? Will I have to have any special tools or any other parts? Any info will be appreciated. It's the 2+2 eliminator axle.
Old Dec 3, 2001 | 06:44 PM
vraptor's Avatar
first go to the durablue page and download the install directions: I received no instructions with mine and they start out with note the order of all the parts on the shipped axle, this will help you do it right the first time. its no big deal your old axle should pop out use a large socket over the threads to tap it out. make sure you use loctite on the set screw (the small hex screw which locks the threads down). one other thing this axle is really a +3 or +5 (+2 or +4 on the banshee its the same axle) I went with the wider setting found my bike got tippy in the tight turns, dropped to the +3 setting and the geometry of my quad is excellent, unless of course you have new extended a-arms. this is an easy install should not take much longer than 30-60min
Old Dec 3, 2001 | 08:27 PM
1996banshee's Avatar
you need to know that you need to take it back to the store because thay are braking all the time and you only get one free one then its $139 to get a new one go with lsr that is what I run on mine and had nothing hapen to it since 1997 entill i ran over my atv with a bob cat. peace
Old Dec 3, 2001 | 09:20 PM
Need4Speed's Avatar
Don't forget to send in your warranty card [img]i/expressions/face-icon-small-happy.gif[/img] Seriously though I have one and I haven't had any problems. Yet.....
Old Dec 4, 2001 | 12:26 AM
chasman's Avatar
make sure when the axle is out you repack the housing with grease.
Old Dec 4, 2001 | 01:08 AM
VMAX12's Avatar
the 2 things you really need are a BIG up to 2.5 in. adjustable wrench (i had to use my pipe wrench becuase i didn't have a big enough cresent) if you use a pipe wrench be careful not to chew up the new axle nut. and use loc-tite on both the axle nut and set screw! oh yeah and
don't overtighten the axle nut....
01 blu 660r
Old Dec 4, 2001 | 01:36 AM
NewDSLover's Avatar
Does anyone have pictures(step by step) on doing this?
Old Dec 4, 2001 | 02:28 AM
need for speed you must not ride hard if you havnt broken one
doug gust uses a lone star with duro blue sticker on it cause they suck so bad
I have broken a stock and a duro blue axle before but lsr is the only one that will take the pain peace
Old Dec 4, 2001 | 08:17 AM
95Warrior's Avatar
Word of caution: if you're putting a Durablown axle on, don't jump it or race it.
Old Dec 4, 2001 | 12:36 PM
MEAN1's Avatar
THANKS FOR THE INFO... I DECIDED ON GETTING A LONESTAR AXLE. I'M GLAD YOU GUY'S WARNED ME ABOUT DURABLUE. ONCE AGAIN THANK YOU!!!!
