pulling baffle out of stock raptor muffler
Old Sep 17, 2003 | 09:46 AM
bad660r's Avatar
Default pulling baffle out of stock raptor muffler
A slide hammer with a puller end on it worked good. I used a pilot bearing puller/slide hammer. Popped right out. I tried everything else. It ended up unusable....but who cares. You'll most likely end up with a pipe later. It will help HP slightly. The air box mods/better filter will help way more.
Old Sep 17, 2003 | 01:38 PM
garyc660R's Avatar
Originally posted by: TitanRacing25
ordered a pro design intake off ebay, should come in soon, and I got the baffle out now. Now I am ready for jets, and the average elevation in KY is 750ft., can someone reccomend me jets, without buying a jetkit as of yet? Is there anything i need to know about the carbs when I change the jets?
The pro design intake is a wise choice for engine longevity. You need too leave the lid on because the stock exhaust with baffle removed will not move enough qir too warrant taking the lid off. Snip the restrictions from the snorkle and use the existing 145 jet in the right side by putting it in the left carb. Now, all you will need is a 150 main jet for the right side. With just the snorkle removed, if I went over 145/150 on the mains, I would get a rich condition and the machine did'nt rev as clean. Good luck.
Firefighter400
Oct 8, 2022 06:38 PM
slowgsxr97
Mar 18, 2022 03:40 AM
brad wheeler
Jul 13, 2015 11:19 PM
cSchwartz
Jul 12, 2015 07:42 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
