ANOTHER RAPTOR CARB ?
Old Jan 2, 2002 | 12:17 PM
VMAX12's Avatar
OK, i have the pro-design kn filter, 2-1 inch uni-vents in lid, the flaps cut out of my snorkle. the stock head pipe has JET HOT coating and the stock silencer. my jetting is 150-155 mains and 25 pilots. the quad runs great with no noticable flat spots. but when i shut the thing off i get a little PUFF out the exhuast? not a backfire just a puff.
now if i had to guess without looking at the plug yet i would say i am a little rich?
what do you think?????? is that the cause of the PUFF
01BLU660
Old Jan 2, 2002 | 01:06 PM
garyc660R's Avatar
When mine was rich a time back, mine would still not have a puff out the exhaust upon shut-off. Have you adjusted/had adjusted your valves? Black puff.....clear puff? Is the baffle removed from the silencer?
Old Jan 2, 2002 | 01:34 PM
VMAX12's Avatar
no i have not adjusted the valves yet. and the silencer is still stock. as far as i can tell the puff is clean or clear. i have about 30 hours on it do you think its the valves?
01blu660r
Old Jan 2, 2002 | 01:44 PM
garyc660R's Avatar
With 30 hrs on the machine, you need to get the valves adjusted ASAP.
With the baffle still in the silencer, I suspect you are running way too rich. A full throttle plug check will confirm this.
On the PUFF, it's probably from an overly rich condition.....baffle probably needs cleaned too.
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
