MY BANSHEE IS HAUNTED ????????
Old Jan 13, 2002 | 08:04 AM
mich660griz's Avatar
i would still have an exersism done on it, you can never be too carefull, lmao!!!
mypictures
Old Jan 13, 2002 | 11:26 AM
Backcountry's Avatar
Slappie's on it...Its probably a lean run-on...The engine gets lean, so the idle raises, it gets leaner, the RPM comes up, it keeps getting leaner, keeps building RPM...It can result in a lean burn down or engine seizure. Give it full throttle, pumping it hard...and it'll come down...It happens sometimes in alky bikes after a hard drag race...
Old Jan 13, 2002 | 11:31 AM
RoostKing's Avatar
Its not only a 2 stroek thing. My 68 Coronet with a 440 overheated real bad on the Arizona highway years ago and did the same thing. Pull the coil wire and it kept running for about 2 minutes. I believe it was so hot it just kept igniting any fuel that was in the cylinder. I heard that its called "desieling" Not sure, but I know its not good!
RoostKing...
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
