Wolverine Headlights need help
Old Jan 10, 2002 | 08:38 PM
ruffryder12771's Avatar
Hey everyone,
I have been having a problem with my headlights. When on low only light is lit but sometimes if you tap it it will come on and sometimes it wont. high beams are fine. What do you think lose wire bad bulb? all help apreciated
Old Jan 10, 2002 | 08:45 PM
slew72's Avatar
Had the same problem. Took the headlight off and had a bunch crud(carbon) on the back of the bulb. Cleaned the bulb and the connector off(wire brush) and it works fine now. Hope this helps.
Old Jan 11, 2002 | 12:57 PM
jcsact's Avatar
I had a similar problem but my headlight had a little moisture in it and corroded the wire and shorted them out. I kept blowing fuses and didn't know why until I found the wire right behind the headlight was burnt from the short I replaced the whole plug and cleaned of the rust with a wire blush and repainted the bare metal. I then silicone after it dried completely. That was the problem I got some water in the headlight and I thought I drained it out before I sealed it up but I guess I was wrong. So it held in the moisture and corroded the connection.
Old Jan 11, 2002 | 01:54 PM
kuz28's Avatar
Same here. my problem had been going on for some time before i addressed it. it must have been shorting where the bulb makes actual contact to the post because, the contact melted. i replaced what was left of the Bulb and had to force a plastic ty-wrap behind the post to force it to make contact with the new bulb. eveything works fine now.
Old Jan 11, 2002 | 02:49 PM
Thanks alot guys one more ? how do you get to th bulb ? does the plastic gaurd come off to get to the headlight? thanks again
Old Jan 11, 2002 | 03:21 PM
jcsact's Avatar
Yeah you have to take the light out of the bracket and then take off the back of it. Be careful when you pull the rubber boot back not to rip it.
Old Jan 12, 2002 | 12:28 AM
Airwolf's Avatar
I had the same problem- intermitent headlights- My problem was corroded plugs- just past the lights- I have since replaced both the stock headlights and plugs as both were prone to moisture damage.
Old Jan 13, 2002 | 10:49 PM
What Kind of lights did you get
Old Jan 16, 2002 | 12:09 AM
Airwolf's Avatar
I got some little 55W halogen driving lights from AutoZone. They work really well and look alot better than stock. They are much brighter and only cost $40. I beleive they are made by Pilot.
Old Jan 16, 2002 | 11:16 AM
jcsact's Avatar
AirWolf
Did you use the stock mounting bracket or did you make a new one.
