GRIZZLY OWNERS..!! NEED HELP IN COLD WEATHER!
Old Jan 17, 2002 | 07:21 PM
GrizzNkodiak's Avatar
I have a 2000 yamaha grizzly, and when the temperature is freezing, the drive selector get's stuck, and won't move from nuetral into drive 1 and 2 or reverse. PLEASE help?
Old Jan 17, 2002 | 08:32 PM
BigDick660's Avatar
If your idle is too high it will be very hard to shift. If this isn't the
case then get some <u>TRI-FLOW</u> and lube all the pivot points of the
linkage and the shifter.
Old Jan 18, 2002 | 07:39 PM
johnpaul's Avatar
check your drain hose
Old Jan 24, 2002 | 11:07 PM
greengriz's Avatar
I had the same problem with a 600 i had it in deep water and some got inside the drive select its easy to fix though, there is a little screw on the bottom of it unscrew that and the water should drip out you may need a hair dryer to dry the inside real good then it should be fine.
Old Jan 27, 2002 | 10:56 PM
NHGrizzly's Avatar
I had a 99 with the same problem. Exactly as the Greengriz said. Water gets trapped inside the shifter. As soon as Winter set in, it froze. You couldn't shift. Do as he suggested. There is a small screw on the bottom. Warm up the shifter or just let the machine run for a while and you be surprised how much water pours out.
Old Jan 29, 2002 | 10:52 PM
Thank you for all your suggestion. I did exactly what greengriz did and now the range selector works. I got all the water out, but now the rear brake is getting locked up, any input would help!
ultangler
Nov 30, 2024 01:35 AM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Elkaholic
Sep 6, 2015 02:44 PM
