Raptor Clutch Questions?
Old Feb 12, 2002 | 06:20 PM
ZRWHAT's Avatar
Installed the GYTR clutch kit and ran into a few problems. First the manual says to line up the two notch's one on the clutch arm and one on the case when the clutch is engaged. Now does this mean when the arm is free, say before you pull on the clutch lever? This would actually be when the clutch is engaged, or are they reffering to when the clutch lever is engaged "pulled"? I have it set right now so that the notch's are lined up without the clutch lever being pulled. But the pull seams very light! Not sure if this is because there is no oil and the engine isn't running or if I have something assembled wrong?
Firefighter400
Oct 8, 2022 06:38 PM
black_thunder
Jul 22, 2015 06:01 PM
brad wheeler
Jul 13, 2015 11:19 PM
200es
Jul 10, 2015 09:09 AM
yambam13
Jul 4, 2015 01:49 PM
