correct chain length with 2" extended swingarm
umm im no math wizard, but in order to figure this out properly, you would also have to know the sprocket size. For instance a 13/34 gearing would require less chain than say a 14/40 gearing. If you already have a plus two swing arm on there i would just wrap a string around your two sprockets, measure out a link, and divide.
I would say a starting point would be, add about 5 inches of chain on to stock chain length, Ill bet you would be close. Sorry i couldnt be of more help. Anyone know a formula?
Derek
Derek
Hmmm, mathmatically sounds like you'll need to find the change in r length for top & bottom of chain where:
r^2 = x^2 + y^2 then measure the length of a link, then divide 2r by link length = # of new links.
The string method sounds much easier huhh, LOL.
