HELP!!!!!! CRACKED FRAME
Old Feb 26, 2002 | 02:36 AM
GrizzMeister's Avatar
I have a 2000 Yamaha Grizzly with almost 4000 miles on it. I have already replace a header and a few other parts. My problem now is that I have cracked the welds that hold the cross member on the rear, and the frame in at least 2 spots[img]i/expressions/face-icon-small-shocked.gif[/img]. I was wondering if anyone had any tips on how to fix it. It is a well used quad and has had its share of air time.[img]i/expressions/face-icon-small-confused.gif[/img] Do you think that jumping it was the main reason for the fractures? IT is riden rough on the trails too!!![img]i/expressions/face-icon-small-happy.gif[/img]
Thanx for all the input
Old Feb 26, 2002 | 02:42 AM
prs311's Avatar
I got two words for you: Sell it.
Old Feb 26, 2002 | 02:54 AM
I would, but I can't afford a new one. Plus, it kinda has some sentimental value--the weekends in the woods with my girl, and it is my first quad.
Old Feb 26, 2002 | 03:11 AM
prs311's Avatar
There's not much to help a cracked frame. If you weld it, you weaken it. Jumping a grizzly? Man thats like putting a 500 pound guy on a horse, thats harsh lol.
Sentimental value or not, pretty soon that bike might not be able to be ridden. It'll just progress as you ride it. If you cant afford a new grizzly, try selling it outright, and buying maybe a scrambler?
Anyways, good luck man.
Old Feb 26, 2002 | 08:10 AM
54warrior's Avatar
IF you weld, just add some extra gussets for reinforcement.
Old Feb 26, 2002 | 10:54 AM
biggy's Avatar
sheeesh dont listen to them welding it will not weaken it !!! the thing was welded in the first place right ?
Old Feb 26, 2002 | 06:37 PM
bermbanger400's Avatar
weld it up and gusset it.it should hold up fine.although i recommend not airing out a grizzly a whole lot just way to heavy,something has to give and it was your frame seems like.
Old Feb 26, 2002 | 06:38 PM
BansheeBrad's Avatar
Weld that thing..
if the welder knows what he's doing it will be as good if not better than new..
just my $.02
Brad
Old Feb 27, 2002 | 12:41 AM
prs311's Avatar
Put some thought into this. If you weld over another weld, its going to be weaker. Your melting the metal twice, and letting it cool back into place. I really think you should avoid the same weld. If its something you really have to do, then by all means do it. I personally would not, even with extensive brackets. Resale value wont be good, and if they know what to look for, they wont even consider your quad.
Old Feb 27, 2002 | 01:12 AM
2tall's Avatar
I don't know what PRS is talking about. Unless the frame is "hardened" welding should not compromise its integrity. As far as I know it's just steel tubing. Go ahead and have a good welder do it,(welded, not brazed) and cut out the jumping....it'll last many more years.
