wolverine sqeeking
Old Feb 19, 2000 | 08:11 PM
wolverine_4x4's Avatar
my wolverine is a 95 ALL STOCK and every time i go through mud or water it starts making this wierd and loud sqeeking sound in the front i think it is my drive shaft and i was wondering what i could to do take care of that noise cause its earatating.the drive shaft is rusted kinda bbad i it might be that but i put some lubricant on it and it still makes a noise so what do i do
Old Feb 19, 2000 | 09:28 PM
boomer's Avatar
Mine did that too. I think it was the shocks, or the rubber bushings in the front. It stopped a while ago. Do a search under wolverine, and you will see that many others had this problem.
Old Feb 19, 2000 | 11:51 PM
Hudgin's Avatar
I drive a 1999 Wolverine, and do some heavy mud riding on it. During the summer, we go riding every Saturday night. The next day I completely clean it with Castrol Degreaser. Make sure you wash all of it off. Then I spray all the metal parts down with STP silicon lubricant. I do not have any squeak problems.
Old Feb 20, 2000 | 12:47 AM
sparkys's Avatar
The squeaking is probably coming from your front u joints. Take the driveshaft guard off and check the universal joints for play in them. The stock ones don't have a grease fitting in them so they don't last long.If you have to replace them make sure you buy aftermarket ones with a grease fitting in them. If you are unsure how to change them have someone do it that knows how.It can be real fun . If you screw up , the front yokes are real expensive.
Old Feb 24, 2000 | 05:07 PM
gwizardzachatv's Avatar
check yor brakes there probly scweaking because there new of you got mud in them spray them off
spray the fromt a arms and suspension cover it in wd 40
Old Feb 24, 2000 | 08:33 PM
ScottA's Avatar
Mine does that sometimes when i'm plowin snow and when im comin out of a creek. ???
-Scott 97 Wolverine
Old Feb 25, 2000 | 02:32 PM
jcsact's Avatar
My 99 Wolv does it to. I narrowed it down to the rubber bushings sweaking on the steal. Also if you just wash it the and then it sets for a will the brakes will get a surface rust on them and cause them to sweak. It should not be that big of a deal. Unless you can hear it when you are riding at high speed because I only hear mine sweak when I going at slow speeds. Engine noise also probably hides the noise.
suzuki230
Jul 8, 2016 10:03 AM
Nelson
Jun 22, 2015 03:51 AM
Nelson
Jun 20, 2015 01:59 PM
ragewraps
May 27, 2015 08:07 AM
holmbergm97
May 27, 2015 07:23 AM
