Rebuilding Banshee Top End Question
Old Feb 28, 2002 | 03:48 PM
SMW's Avatar
SMW
I am rebuilding the Top end of my 2000 banshee with new pistons and rings using the Wiseco kit.
My question is: I thought i read in a clymer manual that the ring Thicknesses are different....and one needs to be on the top, and the other on the bottom. My wiseco kit came with rings that measure the same thickness (.038).
Does anyone know if this is correct?? Anyone have a Clymer book handy???
Thanks
Old Feb 28, 2002 | 04:13 PM
250argh's Avatar
i don't know if this applys to the banshee pistons, but some pistons have a tapered ring groove & taperd ring. you find this out when the ring doesn't fit into the groove. simply swaping the rings will fix that situation. i'd suggest calling wiseco's tech support...they could tell ya for sure!!
Old Feb 28, 2002 | 07:31 PM
the500bansheepilot's Avatar
Yes the rings are suposed to be the same size the clymer was talking about factory yamaha pistons and rings those were different sizes. I am not sure why wiseco decided to make the rings the same size rather than make them two differerent sizes like yamaha did. Hope this helps
Old Feb 28, 2002 | 09:42 PM
HarryMcDermott's Avatar
SMW
When installing the Wiseco rings be sure you put the ( N ) on the rings facing up or they will not seal properly.
Cole Hadden
Jun 15, 2025 09:05 AM
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
