Raptor carb
Old Apr 23, 2002 | 12:52 AM
02raptorboy's Avatar
Is the carb boots blowing off still an issue with the 02 Raptors or did they fix this. Mine back fires sometimes when I first try to start it.
Old Apr 23, 2002 | 01:25 AM
velocityraptor's Avatar
the carb boots were fixed on the 02. If your back firing it means your running a little rich. Your probably over chocking your machine on initial start up! Hope this helps!
Old Apr 23, 2002 | 08:33 AM
garyc660R's Avatar
So what was changed on the '02 Raptor to eliminate this problem? I am aware that the later '01's had revised intake boots.....but have not heard of any other changes. Thanks.
Old Apr 23, 2002 | 09:46 AM
RAPTORAZ's Avatar
<< the carb boots were fixed on the 02. If your back firing it means your running a little rich. Your probably over chocking your machine on initial start up! Hope this helps! >>
If it backfires when opening the throttle, it's lean. A rich condition would result as a bog. You can also tell when it warms up. If it get's better, then it's lean. If it get's worse, then it's rich. I have an 01 that used to backfire when it was cold. I never had a problem with the boots, but then again, I piped it and rejetted it shortly after break-in. I think the carb boot problem was more of a air/fuel ratio problem from the factory. Yamaha jetted them so that the would run okay at most elevations, and the result was that us people at near sea level had to deal with a bike that ran VERY lean.
Old Apr 23, 2002 | 09:57 PM
Right now it is usually 40 - 55 degrees when i start it. Is this the reason for the backfire? It just started about a week ago when I got it back from its tune after the 20hr break-in. It never happens when it is running just the first time I hit the starter button, and it is VERY loud. Thanks for the help.
Old Apr 23, 2002 | 11:23 PM
RAPTORAZ's Avatar
A set of 27.5 pilot jets should solve your backfire problem.
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
