Blaster
Old May 4, 2002 | 04:39 PM
Ward660R's Avatar
What is the 490 origanly from, an old bike? Sounds like a great sleeper, and alot of fun.
Old May 4, 2002 | 07:29 PM
RaptorRidr660R's Avatar
probably an old YZ, but i will let him answer that, I know they was a yz490 maybe in the 80's???? let us know...
Old May 6, 2002 | 05:31 PM
AlkyBurninX's Avatar
As the signature says, it is a 1984 Yamaha YZ490 dirt bike engine. Back in '80, yamaha made a 465 and then punched it to a 490 in 84. Around 86 they made it water cooled, which helped power more. Every one of these motors were VERY powerful. When it was stock and in the bike, a twist of the throttle in 5th (high) gear would yield wild wheelies. Top end with my gearing was found around 95 mph! I know it would pull the front tire at 70 mph. I can't find the exact weight of the engine, but I would say it is only about 10lbs heavier than a blaster. It has only 5 gears and no oil injection. As I said, the exhaust will be fun. The headpipe comes out at an angle, and will have to be turned back forward to miss the frame. Most of the stuff I build is for the shock factor. I love to see the look on people's faces when they see some of my projects. Here is some of the things I have built in the past five years (I'm 21 now).
Whizzer minibike -1.5hp briggs from factory -installed 360cc, twin cylinder, 6-speed, honda streetbike engine. looked good, had highwaybars, electric start, Shriner's envy
Go cart- first had 350honda, then came CB650, then 650nighthawk, and finally a twin cam 750
When the CB 650 came out off the cart it went into a lowered 250r frame- too heavy for the suspension.
225 yamaha moto-4 with a 1000cc v-twin yamaha streetbike engine. Yes, it really was in there. I wish I had pictures. ATV and bike were shaft drive, had to have custom shaft made. Had exhaust custom bent. Way too fast. Had it together about 2 weeks when it dropped a valve and I got rid of the engine.
I've done the 200s into a 200x frame and also a 250x into a ATC250r
Everyone remembers the ford pinto, right. Try driving one with a alminum headed, solid roller cammed, 302 small block in it. One of the scariest things I have built. It would haze the tires at 55 mph.
I also have a 68 ford longbed truck with a solid roller 521 big block stroker (dynoed at around 700hp on pump fuel, and have a 300horse spray on top of that). I love playing with rice burners.
Anyway, I am glad someone finds this swap interesting, since that is the main reason I am doing it. I will be sure to get pictures of this one. If I can find the pictures of the past projects, I will post them in my sig.
Old May 6, 2002 | 06:16 PM
Sorry I did not catch the 84 in the sig. that is my bad, sounds like you have sone some sweet stuff man, keep up the good work!!!!
Old May 6, 2002 | 08:17 PM
  #15
RdingManiac420's Avatar
If your friend has 4000 to spend then he could get a used 400ex. Promlem solved.
Old May 18, 2002 | 11:09 AM
  #16
ANUFSED's Avatar
If i had $4000 for a used bike I would get a used 250r.
Old May 18, 2002 | 12:24 PM
  #17
mojavekid13's Avatar
Dident the old IT490's only have 4 gears???U call it a yz490,either wat dident it only have 4 gears,u are saying it has 5,i think u are fibing somewhere along the line[img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img]
Old May 18, 2002 | 12:53 PM
  #18
Okay, so you caught me. It is an 84 YZ490 topend on a YZ465 bottom. The crank bearings went out of the 490, so I found a 465 bottom to put the ported cylinder on. It has 5-speed. Why yamaha went to 4-speed AFTER 5 is beyond me. Sorry about the confusion, but it is easier to say it is a 490 because most people won't catch the difference. Anyway, I can't wait to see in in the bike.
Old May 18, 2002 | 01:07 PM
  #19
See most people think i dont know that much because iam only 15,BUT let me tell u i know my bikes ,as u can see[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
Old May 18, 2002 | 01:41 PM
  #20
warrior007's Avatar
<< See most people think i dont know that much because iam only 15,BUT let me tell u i know my bikes ,as u can see[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img] >>
Dont know about you but I saw it in another post, oh.. about 2 days ago LMAO
