Banshee with Dyno-Ports...SSSSSLLLLLLOOOOOOWWWWWWW?
Old May 8, 2002 | 03:55 PM
JoshCVBz's Avatar
Hey Guys,
Last night I drove a Banshee with Dyno Ports on it (two pipes, two silencers) and I have a couple of questions.
I took off and 1-4 gear seemed pretty good, but then I hit 5th or 6th (one of the two) and the thing just died out. If I was accelerating at all I would be suprised.
Anyway, I got it back to it's owner and I asked him what was up with that and he said that the dyno ports are for low end power (which I knew anyway), and that they die out in the top gears because he put a 15 tooth front sprocket on it because it was putting too much tourqe on the 14.
He asked me if I saw a difference in low end, but since my Banshee wasn't there I couldn't tell.
Needless to say they didn't impress me much. Are these the typical results from the pipes or is this guy BS'ing me?
Just wondering.
-Josh
Old May 9, 2002 | 02:17 AM
SheeMan's Avatar
What are dyno ports? Pipes?
Even if its a low end mod, it should still pull the top gears if its strong in 1st-4th...I think.
Old May 9, 2002 | 09:57 AM
JoshCVBz's Avatar
Yes, Dyno Port pipes.
I am wondering if it is in fact the pipes causing it like he said, or if he messed with something else.
A mutual friend of ours is buying a Banshee from him and it needs a rebuild. The guy that owns it also mentioned that he will port it as well. I wonder if he had "self-ported" the one that rode and messed something up. Is that possible with the symptoms that I mentioned?
-Josh
Old May 9, 2002 | 10:33 AM
Blaster125's Avatar
It is just over geared. Any motor will fall on its face in high gears if not geared right.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
