Help with sticky Banshee throttle ?
Old May 23, 2002 | 04:04 PM
MITTY26's Avatar
I was wondering if anyone can help me with a problem i got with my banshee ? Every time i go through enough water to splash up to the motor the throttle gets sticky . It last for a bit then goes back to normal. I put a new cable on and also the tors eleminator kit . It was sticky before the changes and it still sticks.
Thanx in advance
Old May 25, 2002 | 06:25 PM
660bigdaddy's Avatar
i wish i knew too. my buddy's shee does the same thing ... a little help here banshee guys
Old May 25, 2002 | 06:46 PM
Fez's Avatar
Fez
I hade this problem with my blaster after putting in a new cable and twist kit. Make sur the cable has enough slack on the handle bars. I use snap-on sythetic lube that keeps my clutch and throttle nice. Buy some it helps a lot.
Old May 25, 2002 | 07:25 PM
copguy02foremanS's Avatar
look in the carb, see if anything isnt right.
spray lube in the thorottle housing.
Old May 25, 2002 | 09:11 PM
lonestarbanshee's Avatar
Mine does it too. Fez, did you invest in an idler kit? Pro Design(i think) makes a kit for the Banshee and the Blaster that helps them idle with a twist. If you dont have it, yours probably wont idle.
2quiker
Mar 22, 2022 08:36 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
