ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Yamaha (https://atvconnection.com/forums/yamaha/)
-   -   Raptor's Rough (https://atvconnection.com/forums/yamaha/66436-raptors-rough.html)
RaptorDisaster Jun 2, 2002 03:49 PM
Some time ago, my Raptor started to have problems with a consistent idle. sometimes it would idle high, sometimes low. Even after it was warmed up. Now, it also spits and sputters, mainly when hitting whoops and such. The spark plug has plenty of black soot on it. Air filter looks good. Boots look okay. I've seen lots of different suggestions here, but can anyone narrow it down some?
Thanx.
Raptor690 Jun 2, 2002 04:03 PM
Could be your carb. boots are cracked,ripped or slightly off just enough to allow air in it when you are hitting bumps
RaptorDisaster Jun 9, 2002 06:01 PM
I pulled the carbs to have a look at the float setting. But before I got that far, I found that the starter/choke plunger wouldn't come out like it's suppossed to. Looks like water got past the cable and into the spring area. It corroded enough to eat up the spring some and prevent the plunger from moving freely. If the plunger was off the seat a little, it would explain the rich looking plug. Also, the floats were set to allow a way high fuel level. I'm waiting on a new plunger & spring. Should be in this week.
NotuRaptor2 Jun 9, 2002 09:21 PM
I am sure you figured it out already. I was going to tell you this was the most likely culprit. KNOWSALOT posted about this issue and the part numbers for the cables too. Yamaha has a service bulletin. It also includes Kodiaks.
I bought the cable but not the other parts. I cleaned the plunger up really well and bought another spring from the hardware store (had to cut a few coils from it though). All is well now.
/NotuRaptor
RaptorDisaster Jun 10, 2002 12:05 AM
I didn't know about a bulliten from Yamaha about this.
Can you give me a quick recap of what KNowsalot said?
Thanx loads.
wshrdskin Jun 10, 2002 12:21 AM
Here ya go Raptoristhebest, [img]i/expressions/face-icon-small-smile.gif[/img]
Raptor Tech Bulletins
727Banshee Jun 10, 2002 12:34 AM
He said that the 2003 were coming out next week and he said that he wasn't sure if they were going to make the banshee in 2003
URPREY Jun 10, 2002 05:10 PM
I had that very same problem! I was going to suggest it, but you're on track now [img]i/expressions/face-icon-small-smile.gif[/img]
RaptorDisaster Jun 10, 2002 05:39 PM
URPREY,
what exactly was yours doing when you found this problem?
Big55Sexy660R Jun 10, 2002 11:23 PM
Check your parking brake my buddy was having the same problem with his raptor and the dealer showed him that if your parking brake is stick it will cause if to sputter.check out it might you.
© 2026 MH Sub I, LLC dba Internet Brands
