Compression Check on a Raptor
Old Jun 4, 2002 | 11:51 AM
NakedRaygun's Avatar
Does anybody know the correct procedure for checking compression on a Raptor?
The spec is 181psi but I am getting 90psi.
I think the reason for the low compression is the compression release but the service manual does not give any information about disabling the compression release before testing compression.
I am putting 45 RWhp to the ground out of a stock 660cc engine (pipe and carb mods only)so I would find it hard to believe that I have that much compression loss.
Any information would be appreciated.
Old Jun 4, 2002 | 11:59 AM
FISHER1648's Avatar
The raptor has a centrifugal compression release. At low (starter assisted) RPMs the compression is released. As soon as the RPMs build there is full compression. From what I understand, a good fully charged battery is needed to get the RPMs high enough to dis-engage the release. I hear that if ya attach a battery charger to the battery for the compression check it will get the proper RPMs for the test.
Please let me know how it turns out -
Old Jun 4, 2002 | 12:51 PM
THEMOOSE's Avatar
Make sure the valves are properly adjusted,
Warm the engine up fully,
attach a battery charger to get it spinning fast enough to override the decompression device &
make sure you hold the throttle wide open when your cranking.
That should give you a correct reading.
If your getting 45 HP you should have plenty of compression.
Do not leave the battery charger on boost for a long period of time or you can fry the battery.
Old Jun 5, 2002 | 12:19 AM
Thanks for the replies.
I'll give your suggestions a try.
I know that I did not have the throttle wide open when I checked it.
Old Jun 5, 2002 | 12:25 AM
THEMOOSE's Avatar
Holding the throttle open will make a big diffrence! Those puppies need to breath to get the right readings!
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
