Raptor exhaust ?
Old Jun 16, 2002 | 09:45 AM
Quadpilot's Avatar
What gains would I see if I installed a slip-on, vs. the complete exhaust system ? I'm not against getting the full exhaust, but I don't know if I need it. I'm looking for more low to mid range power, the top end is plenty for my riding style. Thanks
Old Jun 16, 2002 | 10:41 AM
desracers's Avatar
quadpilot
You could get the WB E-series they have good low and mid range. If the noise is an issue get the slicencer core to add on it.
Old Jun 16, 2002 | 07:09 PM
wannaberacer's Avatar
ATVtesting.com says the White Brothers E-series has a ton of low end. Sounds like what you are looking for. I think it had the lowest dB reading of the pipes they tried too. Hope this helps.
Old Jun 16, 2002 | 10:02 PM
727Banshee's Avatar
Get the yoshi complete exhaust system cause it gives excellent performance over stock I think up to 46 hp if you want more I believe dirtwheels did a roundup of raptor exhaust systems.
Old Jun 17, 2002 | 12:00 AM
desracers's Avatar
Quadpilot
You might be happy to get the full system exhuast. Everybody have their opinion of the pipe they have.
I used to have WB E-series before I switch over to LRD.
Two things I did, one is nosie that LRD is must quite then WB E-series with the silence core on it. About 4-5 db different. The other is it got more broad band of torque and hp then WB.
I really like it alot.
LRD told me the hp range is around 46 to 48 on stock motor with the proflow filter set up.
That my answer to this.....
Bill
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Sep 10, 2015 01:56 AM
Bigtwin700
Sep 9, 2015 09:32 AM
1ArmBandit
Sep 8, 2015 08:59 PM
black_thunder
Sep 7, 2015 01:24 AM
