Grizzly Main jet
Old Mar 13, 2000 | 05:12 PM
wgr's Avatar
wgr
Has any one experienced needing a larger main jet in a Grizzly due to a top speed miss.If so what size of jet did you use.
Old Mar 14, 2000 | 02:31 AM
tdhusker's Avatar
I wonder if you really need a larger main jet or if you are just overreving your machine? My guess is that you are doing the latter. If your machine has the stock jet that was meant for sea level, my guess is that you are just bumping the rev limiter(if the grizz has one??) or floating the valves. Either way, i would refrain from doing so in the future.
Old Mar 14, 2000 | 11:28 AM
wgr's Avatar
wgr
I am down about 10 miles an hour on top speed,iam wondering if one of the clutches are not working properly,I replaced the belt,and inoticed the wear marks on the drive(primary)clutch were about 3/4 of a inch from the top of the clutch,any one know how high the belt should ride when shifted out.
Old Mar 14, 2000 | 07:44 PM
wgr's Avatar
wgr
Thanks for info,it was the primary clutch,not shifting properly,the grease was mixed with dirt and dogfood,that a mouse hadbrought in.
shimanok2
Jan 29, 2016 07:37 PM
MooseHenden
Family ATVing Photos
Oct 5, 2015 08:14 AM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
