wolverine and dyno jet
Old Mar 19, 2000 | 02:29 PM
wolverine96's Avatar
I have a stock wolverine and was wanting to up grade it. Does the dyno-jet kit from K&N make a differance what else can I do to up grade it??
Thanks alot, Bob
Old Mar 19, 2000 | 03:06 PM
sparkys's Avatar
The first thing you want to do is get rid of the stock exhaust and buy a good aftermarket pipe.
You need to increase the ex. flow before you can really start to do other mods.I chose the FMF Megamax II because I liked the looks of it, the sound of it , and the improvement in bottom end and midrange power. You should also get a better flowing filter like a K&N. Also venting the airbox lid gives you much better throttle response and its a cheap mod to do.I personally dont like jet kits because there are better ways to spend the money that will give you more improvements in performance.I also reccomend 25" tires cause they will give you better ground clearance and more top speed. But they will rob a little bit of power. The next thing I am going to do is install a .040 over Wiseco piston to raise the torque even more. Then maybe a .390 lift cam th finish it off. Then the other mod to do is the 500cc BIG BORE......... Maybe some day!!!
suzuki230
Jul 8, 2016 10:03 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Cantbuytime
Aug 17, 2015 06:33 PM
Nelson
Jun 20, 2015 01:59 PM
