alba pro-comp a-arms?
one more thing.
when they say +2 does that mean 2 inches on each side or 2 inches altogether?
and +2 +1 the plus 1 part that is foward 1 inch right, what does that do give you more wheelbase length?"
thanks
thanks
Ok, I see...
The Competition arms have heim joints conecting to the pivot tubes on the uppers for camber and castor adjustment. The are also milled steel. Do you have to pull the pivot tube to adjust the heim joints???
The Pro-Comps do not have heims on the uppers and are chromeoly.
From Alba site regarding Pro-comps...
<< The optimum castor is already built in to the A-Arm eliminating expensive Heim joints. The camber can be adjusted while on your Raptor by loosening or tightening the jamb nuts. No need to remove, adjust and reassemble as with other A-Arms. >>
