Installed the Lonestar rear subframe on the Raptor
I bent the factory aluminim subframe in endo crash. I figured a chromoly unit would be worth the $380. This piece is very will made except they didn't include any way to mount an external shock reservior. I am going to call them tomorrow to see what they say. I ordered the subframe for a 2001 Raptor so they should have known I have the reservior to deal with. Due to the design of the Elka reservior, I can't just clamp it to the frame. I need some type of spacer. Seems to me I remember reading a solution to this on this forum but can't find it now doing a search.
By the way, this subrame fit perfectly and every screw hole was perfectly placed and easy to thread. The powder coating was flawless (even though you can't see any of it once everything is installed.
Any advice? I am pretty crafting and thinking carving a spacer out of wood but maybe someone already makes rubber ones.
Thanks,
NotuRaptor
Thanks,
NotuRaptor
a friend of mine has a little rubber pice that goes between the frame and the rezzzys on his shocks i will find out where he got theme for you but i think it was White brothers
as for your subframe let me know how it comes out0
