What more?
Old Sep 17, 2002 | 11:41 PM
Yamalip's Avatar
I have a 96 blaster that is ported and polished piped and bored 60 over. I was woundering if there were anythings i could do to increase the power. I wanna race this spring so i want to get it at peak power.
Old Sep 17, 2002 | 11:51 PM
maddog56's Avatar
definately go with a pipe, jets, carb, and an aftermarket air filter
these are all pretty much the basics of 2 stroke upgrades
Old Sep 18, 2002 | 12:01 AM
JakalWarrior's Avatar
Well, more power eh? Figure out how to feed that little sucker. Only problem is a small restrictive intake that cant quite feed a motor that big. Either work around it or deal with it. Im guessing since it dosent have the feeding capabilites that if you big bored it, it would just gain a boat load of tourque. A more potent fuel is also an option, its all up to how much more you want. With 200ccs or so of two stroke, expandable to 240 or so you can do a GOOD bit. I dont see why if properly fed and with the proper exhaust it couldnt make 50hp, just so much work between here and there... would be cheaper to go ahead and buy one with that much power already.
Old Sep 18, 2002 | 12:15 AM
Yamalip's Avatar
I was thinking about steping up to a 250r, but the only problem is that they want more for them now then they did when they came out. Also what is a good set of padles for my Pops raptor?
Old Sep 18, 2002 | 12:30 AM
YFZRacer's Avatar
toomey pipes, jets, air filter remove lid, and if you want more get the CT 240 Kit with 40hp
