wolverine question
Old Sep 26, 2002 | 11:37 AM
gatron777's Avatar
a friend has a a wolverine with a supertrap pipe he has 7 plates in it and when he is in 5th gear his rpms wont get up to what they should be its been jeted but he doesnt know what size does anyone know what size it should be and he said he took his filter completly out once and it still did the same thing can anyone help him with this? the bike works good on bottom end but not on top end .any help would be appreciated.this site is awsome.
Old Sep 26, 2002 | 12:11 PM
Murph660R's Avatar
7 plates is very restrictive. I had 8 in my supertrapped wolverine and it was more restrictive than the stock pipe but it was quieter which is what I wanted. I don't know what jet size he should be run'n but something doesn't sound right. Is he running larger tires?, will it rev out in lower gears? Did he do a plug check?
Old Sep 26, 2002 | 03:13 PM
gatron777's Avatar
it will rev out in lower gears his plug is fine and he has 26inch tires on it bear claws front and mud bugs back
Old Sep 26, 2002 | 06:41 PM
jcsact's Avatar
I am grabbing straws here but the different make of the tires could possibly be the problem. They might say they are the same height on the sidewall but they could actually have a different circumference. You might want to check that. He could be tearing up his differentials. Plus a 26" tire is pretty tall for a Wolv. It already lacks low end power and he just took it all away when he put tall tires on. That is just my 2 cents though.
Old Sep 26, 2002 | 06:50 PM
JakalWarrior's Avatar
Yeah, the gian tires are murdering you. Not only do they raise your gear ratios but they have a larger mass and waste more power being turned. If your gonna have tires that big i say get a high compression piston and maybe a torque stuffer (dont they hurt top end?).
Ohhh.. and forgot something, if you made your pipe more restrictive dont you need to lean it out? look at your plug and see if its all black, also you can look at the inside of your tail pipe and see if its a rich rich black. That means rich. Which would cause your loss of top end.
Old Sep 26, 2002 | 07:01 PM
gatron777's Avatar
i will let him know thanks for the info fellas.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
