What Spark plug do you use in your raptor
Old Oct 21, 2002 | 05:48 PM
weasle's Avatar
Default What Spark plug do you use in your raptor
Is there a better spark plug to use then the stock one?
thanks
Old Oct 21, 2002 | 06:33 PM
Raptoryfn660r's Avatar
RIP Dear Friend
I have always used the standard plug an change it after the riding season is over.
(NGK) DPR8EA-9
Chet
VP Knowsalot Facility
Old Oct 22, 2002 | 04:03 AM
raptor8's Avatar
nope i just use the stocker. most of those other things are just gimmicks - believe me- car biz 32 years now...
all the plug has to do is spark. thats it. stocker works fine for me.
[img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 22, 2002 | 06:48 AM
Ward660R's Avatar
Pretty good info airraptor. Do you think it might have had something to do with the way the plug was facing, or indexed if I am right?
Old Oct 22, 2002 | 10:11 AM
RIP Dear Friend
To the effect that if you can face the plug correctly the flame front will/should travel better.
I have never done this and would not have a clue which way the plug should face in the Raptor with all the valves in the chamber.
Chet
Old Oct 22, 2002 | 10:51 AM
THEMOOSE's Avatar
I just use the stock plug myself.
I replace it every 20 hours when I adjust the valves since I'm in the neighborhood.
Most people I've asked has said the Splitfires are worthless, I guess the platimum (sp) plugs would be ok but they are made to last longer than regular plugs so I don't see an advantage to using them in an engine that has it's plugs replaced often.
On plug indexing, It's been proven that it makes a diffrence. If I remember right you want the open end of the ground strap pointing torwards the intake valve, so am I right in thinking you'd want it pointing at the center intake valve on the Raptor?
Old Oct 22, 2002 | 11:26 AM
RIP Dear Friend
THEMOOSE,
What happens when you tighten it down and the plug is facing the wrong way? I guess I have never paided attention to plugs but are they all machined, the threads in the same position or is it the luck of the draw where the tip ends up.
Chet
Old Oct 22, 2002 | 11:45 AM
RIP Dear Friend
BartlettRacing,
That's what makes these forums good. I can learn something new about everyday.
I have never heard of indexing shims and don't pay much attention to my plugs other than making sure its the correct plug and putting in a new one every season.
I guess, I should change it maybe twice during the season. When I take them out they always look Ok but I change the plug anyways.
Chet
Old Oct 22, 2002 | 11:49 AM
THEMOOSE's Avatar
Originally posted by: BartlettRacing
paint a mark on the porcelin at the same location as the opening on the electrode then when tightening it down make sure it faces the intake valve .you may need to shim it .with indexing shims
Yea, what he said!!
Better late than never!! LOL!![img]i/expressions/face-icon-small-blush.gif[/img]
Bartlettracing, would it be better to have it facing the center intake valve or as long as it's facing any of them it would work?
Old Oct 22, 2002 | 03:55 PM
Ward660R's Avatar
It seems to make sense that it should be towards the center intake so when the mixture comes in all three nothing will be in the way of the spark.
Airraptor that would be great if you could share that with us.
