Where are the air screws on the carbs located.
Old Oct 22, 2002 | 03:44 PM
weasle's Avatar
Default Where are the air screws on the carbs located.
I just want to make sure I'm gonna be messing with the correct ones. When you guys say to run the air screws in, then run them out three turns, which screws are these. My bike is still running a little rich, and I want to see if this helps.
Thanks
btw, pics would be a bonus [img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 22, 2002 | 04:22 PM
2fiftyX's Avatar
The air screws are in front of the float bowls of each carb. under each carb there is 2 holes, one of the holes does not stick down as far as the other, inside this hole is where the screw is located.
If you figure out an easy way to adjust these without taking the carbs off please let me know. I have heard of someone on here welding a "T" to the screws for easy adjustment but that would mean I would have to take the carbs off when I'm not even sure if they need adjusting.
Old Oct 22, 2002 | 08:35 PM
RacinJason's Avatar
motion pro makes a tool for about $12 which will allow adjustment with a steady hand ,use a mirror to double check your work.
Old Oct 23, 2002 | 11:01 AM
Murph660R's Avatar
Use a small driver (long style) bit that is for a cordless drill. It is tough to get at but you can do it. By the way, being ahead of the needle (towards motor) make this a fuel screw not an air screw. More turns out = more fuel.
Old Oct 23, 2002 | 11:52 AM
sandjunkie's Avatar
What is the max turns out you can go?
Old Oct 23, 2002 | 12:20 PM
2fiftyX's Avatar
Good point Murph660R! But I think more technically it's called the air/fuel mixture screw.
I tried using a screw bit but can't get my hand positioned right to turn it.
sandjunkie, I believe after 4 turns out there is no increase in fuel.
Old Oct 23, 2002 | 12:30 PM
Murph660R's Avatar
You are right 2fiftyX. I hear it called an air screw all the time which can be misleading. I had a tough time adjusting them without removing the carbs but I did do it. I used my fingertip on the bottom of the bit to hold it and a small wrench to turn it while counting the flats. Not wanting to remove the carbs again motivated me enough to get it done.
Old Oct 23, 2002 | 01:05 PM
weasle's Avatar
thanks guys, are they philips or flat head screws btw?
Old Oct 23, 2002 | 01:11 PM
2fiftyX's Avatar
standard "flat head" screws.
slowgsxr97
Mar 18, 2022 03:40 AM
Aitch
Jul 21, 2015 09:40 PM
ghost civic
Jul 20, 2015 12:36 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
