Why does my Raptor keep Stalling?
Old Oct 31, 2002 | 06:00 PM
joeyd's Avatar
Default Why does my Raptor keep Stalling?
Ok i have like the most anoying problem..my raptor keeps stalling out in the turns..and especially below 1/4 throttle
I have the following mods:
Full Yoshimura RS-3 Race series Pipe with Titanium Canister and stainless steel headpipe
* Dynojet stage 2 jet kit 146 and 148 jets
* Graydon Proline alumunim airbox with K&N 250R style filter with Outerwear sock and airbox lid
* K&N crankcase breather
I thought at first that it may be bad gas...i drained all the gas was running fine then all of a sudden it stared again after about 7 laps at the local track. wheni went home i noticed that my crankcase breather filter was gone. Could that be causing my problem? or isit the Graydon aluminum airbox that is giving me fits?
Please help..thanks in advance
Old Oct 31, 2002 | 06:03 PM
velocityraptor's Avatar
has the temp. where you live dropped drasticly lately?
Old Oct 31, 2002 | 06:26 PM
joeyd's Avatar
well yes but it also didi this back in july...when it was rather hot..
the guy i bought the airbox from mentionned something about putting spacers under the airbox to shimmi it up a little so that it wouldnt push the carbs down..making the floats unlevel..i dunno... im ready to put the stock airbox back on
Does anyone else run the Graydon airbox? have you had any problems?
Old Oct 31, 2002 | 07:48 PM
BlueLeader's Avatar
Joeyd, glad do see you didn't sell the Rappy!!!!!! If you want I will take the airbox back if you are unsatisfied.
There are 2 mounting holes on each side of the airbox. you can raise or lower the airbox by raising or lowering the mounting tabs by using 1 bolt on each side instead of 2.
But why did it run great before and not now. Bad gas? Bad plug? Dirty filter? Float problem? Valves? Choke?
We will figure it out. Don't wory.
Scott
Old Oct 31, 2002 | 08:13 PM
joeyd's Avatar
Scotty !!!!!!!!!!!!
hey man i heard about your fall..hope you get better real soon...i was hit by a car when i was younger on my quadracer..i have a steel rod in my leg..check out this video clip wheelie king i just dug up this was take about 2 weeks prior to my accident
Yeah it was running great for awhile..im going to go home and mess with it..do what you say...i mean the airbox makes a huge difference
i m goin to play with it and get back to you
nice to hear from you again red leader out
*psst*
Old Oct 31, 2002 | 08:19 PM
BlueLeader's Avatar
early on I had a problem with the dynojet kit. I would stall out if I let off the throttle when coming to a stop or cresting a dune. it was so long (and mods) ago that I can't remember what I did to fix it. I bet you are lean with the temp drop. Try 148/150 mains and needle in 3rd clip.
Scott
Old Nov 1, 2002 | 04:55 AM
RichieRoadRash's Avatar
2 things...check for a split in your carb boots or your floats need setting. i've had both problems and what you described is what was happening. good luck.
Old Nov 1, 2002 | 07:41 AM
RaptorRider660R's Avatar
What about your pilot jets? I just put on a pro-flow and no lid with a dyno-jet kit using 148-150 and I'm having the same problem it wants to stall at low speeds i need to blip the throttle to keep it going when I come to a stop. Some one recommended going up to 27.5 pilots when running no airbox lid. I just ordered the jets I'll let you know if it helps.
Nocando
Old Nov 1, 2002 | 12:38 PM
garyc660R's Avatar
Apply a little choke and see if the problem gets better or worse. Try too determine exactly what throttle position this is occuring at.....then you know at which fuel circuit the problem lies.
Old Nov 1, 2002 | 01:10 PM
ShaK's Avatar
start simple
your idle might be to low. I was told all the same stuff as above, when the only problem with mine was idle to low
