EGT
I have those on my Banshee when I had the T-4 pipe and now I have T-5 pipe and need to install on T-5 pipe. When I have those on T-4 and they work pretty good. It tell you what the temp is at. and so on. The max. temp you really want to run is around 1300 degree. I set it up around 1150 to 1200 degree. That way I am in comfort zone. It was easy to install. The brand I had was digatron, they are based from Spokane, Washington.
I am sure they have for the 4-stroke.
Desracers,
Where did you get your EGT and how much did you get it for? I was looking for one for my LT500R and the only place I could find one, was at a ultralight aircraft supply and the cost was extremely expensive! If you could help me out with this I sure would appreciate it! [img]i/expressions/face-icon-small-smile.gif[/img]
OutCast
Here the number of the Digatron of Spokane , Wa.
509-467-3128
I order mine thur the mag. of dirtwheel a few yr backs from ATV Racing. I think I pay around 300 or so, can't remember it. That was for the dual probe. since you have single it would be cheaper.
Give them a call and see what happen.
509-467-3128
I found one for $220.00, but it's a Large Display TACH / EGT Gauge. That is the only one they have. I wouldn't mind having a Tach, but it's a little hard to watch a digital display over an analog one. I will have to give it some serious consideration though.
edit: I found a EGT gauge only for $145.00 I think I'm going to be getting that one!
43KL series
43KL series
Look at aircraft supply places. Here's a few names
Aircraft spruce & specialty www.aircraft-spruce.com
Gulf coast avionics
Cheifs
San Val
The only down side I can think of is not using it right.What I mean is once you reach peak you can lean it more (over Peak) and the temp will come back down slightly.Not being aware of this could cause problems.
Gulf coast avionics
Cheifs
San Val
