400cc blaster?
Old Nov 17, 2002 | 10:40 AM
iamchad2k5's Avatar
Default 400cc blaster?
i have an old suzuki ts400 dirtbike. its a 400cc 2-stroke, the first big bore dirtbike that suzuki made. and my friend had the idea of throwing the engine in a blaster frame. just because it would be fast, and the wheelies would last forever. if anyone knows anything about blasters and they're frames, and or the size of the ts engine, and if it will fit, it would be nice if you could respond to this. thanks
Old Nov 17, 2002 | 11:35 AM
StevieD's Avatar
i think you should just leave the blaster alone. if you put the 400 engine into it, it wont handle cuz itll have so much torque and vibration. it would do some sweet wheelies, though.
Old Nov 17, 2002 | 12:27 PM
quic89's Avatar
ya ain't got the wheel base or width to handle that old 70's ts400--had 2 of them back then ---tell's on my age/just ride the blaster or get somethin else----that was as bad a sled as the yam sc500---iffen ya that old --HAVE FUN
Old Nov 17, 2002 | 01:02 PM
albaBANSHE's Avatar
But if you still want a blaster frame and other parts(used) go to www.rathracing.com
Old Nov 17, 2002 | 01:03 PM
albaBANSHE's Avatar
oh,chad i cant get your site in your signature to work?
Old Nov 17, 2002 | 03:40 PM
YFZRacer's Avatar
that would be a fast quad man 400ccs of 2stroke in a lightweight frame
blaster 2 fast is putting a yz250 in his next year so i'd talk to him
but you will definatly do some bracing and stuff cause it would have way more power then the stock engine and it will vibrate and rattle lots
you'll also want to get it longer and wider cause you'll need it to be more stable with all the power
good luck
Old Nov 17, 2002 | 05:21 PM
blastermaster288's Avatar
yeah it would do good wheelies until the frame brakes from the torque and vibration lol the frame would probably twist or brake with that much power i think the frame couldn't handle it.......but good luck if u try it....
Old Nov 17, 2002 | 05:23 PM
yeah and if i was u and i was doing it i would strip the blaster down to its frame and get the frame reinforced just for precautions...like i said good luck...[img]i/expressions/face-icon-small-confused.gif[/img]
Old Nov 17, 2002 | 07:14 PM
YFZRacer's Avatar
ya i could see the frame falling apart to do some major bracing
Old Nov 17, 2002 | 10:39 PM
87Banshee250sx's Avatar
Aaron, you know the TS engine in a Blaster would be "off the hook!"
lol
-nick
