Timing plate stock on 99 Banshee??
Quaders,
I have seen some posts regarding timing plates on Banshees. I know you can buy aftermarket plates, but does the Banshee come With one stock??? If so, what do you recommend for timing?
Thanks,
RoostKing...
Thanks,
RoostKing...
roostking.
I had the stock timing plate machined out so that it can be adjusted. I had CT racing do mine when I did the 370 long rod...
my suggestion would be to see if you can get a good look at a pro design plate and have your stock plate machined
good luck
good luck
Jul 7, 2015 11:00 PM
